Originally posted by 1987cp
Ported E7 Flow Numbers
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I was advised against the Bcam from a few GMNers including Turbo...it's duration is too high...it's 224* at .050" lift...too high.
So, Mike...that "dyno" sheet is with an E303 cam/1.72 RR...so my exact setup, right? it looks like it...
I wouldn't expect the hp #s to be that high(470ish at 6500rpm) but I would imagine more like 400-420ish....max...but we shall seeLast edited by Mr. Land Yacht; 05-09-2007, 11:57 AM.sigpic
Originally posted by Nathan in MN View PostThat's an odd quirk of Desktop Dyno. With just about any combination, switching from dual plane to single plane adds about 50 hp. That doesn't mean it would actually happen in the real world. Just slap on a dual plane and go.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by Mr. Land Yacht View PostI was advised against the Bcam from a few GMNers including Turbo...it's duration is too high...it's 224* at .050" lift...too high.
I was also pretty surprised that DD claimed as much power as it does. I did notice, for example, that the torque output is rather optimistic for a stock 5.0 HO motor, and while the power at the factory-rated horsepower peak is correct, the simulated peak is a little higher up - so right, I'd guess these numbers could possibly be a little optimistic. If the output were known to be reliable, I'd be pretty keen on building the engine, doing whatever is needed to keep it spinning between 3500 and 8000 RPM - probably with some deeper gears and reducing the car's weight some - and see what it does!2012 Mazda5 Touring | Finally working on the LTD again!
I'm not sure about the valve sizes...We'll have to wait for Turbo to see this thread again
Gerry never said anything about making the valves larger...so I'd assume they are the stock size(whatever that is )Last edited by Mr. Land Yacht; 05-09-2007, 12:54 PM.sigpic
Mine was run using stock valve sizes and the flow numbers from my particular heads. I don't have the sheet but no real reason to expect it to be much different than yours.
Nate: the effects of the dual plane really vary with the cam. Generally speaking it helps on the bottom and hurts up top but some cams don't work well at low rpms, so the intake really won't change much.
http://www.jason.fletcher.net/tech/camlist/cams_rol.htm if anyone wants the specs on the FMS letter cams and a bunch of others.86 Lincoln Town Car (Galactica).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by gadget73Nate: the effects of the dual plane really vary with the cam. Generally speaking it helps on the bottom and hurts up top but some cams don't work well at low rpms, so the intake really won't change much.
yeah its definitely not the most accurate thing on earth. Seems to me some of the numbers it chugs out are somewhat pipe dream-like. Its somewhat useful comparing what a single change would do to the power bands, but it really isn't the final word fo sho.86 Lincoln Town Car (Galactica).
Don't people usually assume something like a 15% loss through the driveline? There are probably different figures to use for a manual versus automatic transmission, too, or if you run a harder-to-turn rearend like a 9".2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by Mr. Land Yacht View PostI'm not sure about the valve sizes...We'll have to wait for Turbo to see this thread again
You have the 1.94/1.6 SS valvesScars are tatoos of the fearless
