I ditched my efi. Got the carb on and it runs. Need to drop the tank still and remove that pump on saturday. Picked up an ho cam and heads for 50 bux. Put the cam in, the heads need a valve job. I pulled the motor and changed every gasket, seal and plug in it. So no more leaks. For nearly 250k, I was amazed upon opening it. You can still see the factory hone marks, and there is no groove from the rings wearing. The lifters still fit tight in the holes, and there almost no sludge. Im happy. Put on a new water pump as well. Discovered why my old gasket blew, the back intake water passage was packed solid all the way across. Oh well. Its carbed now. Im happy. Pics soon of my setup.
Hahahahahahahahaha
Hahahahahahahahaha
1989 Grand Marquis LS
flat black, 650 double pumper, random cam, hei, stealth intake, Police front springs, Wagon rear, Police rear bar, wagon front ,exploder wheels, 205/60-15 fronts 275/60-15 rears, 1 5/8" headers, 2.5" offroad x pipe, Eclipse front bucket seats, Custom floor shifter, 4.10 gears, aluminum driveshaft and daily driven. 16.77@83mphTags: None
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by 88VicYea, now you can tune it yourself. I can't wait to learn how to rebuild and tune a carb myself.
Its easy. Swap isnt hard but long and complicated, especially when pulling the motor.1989 Grand Marquis LS
Originally posted by Nathan in MNCome on up next summer, Dan. I'll teach ya a thing or two.88 Town Car (wrecked, for sale)
another car with a calibrated vacuum leak
Yep, carbs on an EFI car can make life a lot simpler. I went ahead and got a tank for a carbureted car, then hacked my fuel-level sender and made it into a 3/8" pickup. I have extra inlet screens in both 3/8 and 5/16 if you need one, as well as an extra brand-new filler neck grommet.2012 Mazda5 Touring | Finally working on the LTD again!
Ill rig somethin up for the pickup. Ill let you know if I need something though. Im glad too. The rear one was sucked in on it.1989 Grand Marquis LS
Making a pickup is friggin easy. Take out the electric pump and put a length of 5/16" fuel line in and clamp it down...That's all I did on my carb swpa on the V8 conversion on my stang.Builder/Owner of Badass Panther Wagons
Originally posted by mrltdMaking a pickup is friggin easy. Take out the electric pump and put a length of 5/16" fuel line in and clamp it down...That's all I did on my carb swpa on the V8 conversion on my stang.
Since I'm usuing a mechanical fuel pump.sigpic
Yeah.
One note though, you might want to do a bit more than that. I noticed the wagon's pickup crimps down where the hose connects. I would cut that off and then put the hose there. You could replace the whole section of tubing on the pickup with something larger if you wanted to get really fancy. Though with your motor, you really need to go with larger fuel lne from the tank. The limit on stock lines (with a carb) is 300hpBuilder/Owner of Badass Panther Wagons
I used 3/8 tubing for the pickup. I also redid all of my lines with 3/8 cause the old shit was rusting apart. I also put a screen on it too.
