as many of you know i attempted to do a 4 bbl swap not to long ago, and it went down the drain beacuse the intake is warpped, i am wondering if it can be surfaced, and how much would it roughley cost? Or am i probley better off buying a new one off ebay or somthing, like maby one with bigger ports etc...?
Intake re surfacing
what is warped? The carb pad? the intake head mating surface?http://secondhandracing.com/Home.aspx
You can have it milled true, but if it is just a stock factory lower you are better off just getting a new one.http://secondhandracing.com/Home.aspx
Replace it. If someone cranked it down or overheated it bad enough to warp the thing, I'd fear metal fatigue and possible cracking or something. Stock 4v intakes arent that expensive or hard to find. Ebay is your friend. Probably cheaper to replace than have that one fixed.86 Lincoln Town Car (Galactica).
