Edelbrock is selling a EFI manifold that is based off the carb'd super victor intake. The intake is $350 the required fuel rails are $80, you just add either a 4150 style throttle body or an elbow and a regular throttle body. This should fit under a stock hood with just some removal of some bracing. They are best suited for either big inch windsors or high RPM motors
FORD 351W V8
SUPER VICTOR 351W EFI (Up to 8500 rpm)
Super Victor 351W EFI is based on the Super Victor 351W manifold #2924. Designed for high rpm or large displacement high performance 351 Windsor Ford V8s with a deck height of 9.5" which operate between 4500 and 8500 rpm. Can be used with ported cast iron or aftermarket aluminum heads, such as Edelbrock Victor Jr. #77169 or Victor heads #77219 for ultra high-horsepower. Runners have a 3.20 square-inch cross sectional area.
FORD 351W V8
