Transmission Buzzing...?
    Just found out about this...
    I had the door open I was backing up slightly.
    When I shifted into drive, something started buzzing. Going through the gears; it buzzes in 1, D, and OD; but not in N, R, or P...
    Any ideas?
    I have a slight leak in my trans lines; they need to be replaced; MrLTD saw this. Would that mean that I am low on tranny fuel? Any special kind I should add?
    Evidently the AODs have a tendency to buzz, because there have been threads about this before and everyone says they just do that. Still, I've never experienced it. *shrug*
      that's normal Scott for the aod to buzz mine does it. I also need to change the tranny fittings
        My fresh rebuilt one does it also.
          yea, mine does it, too...sometimes I can feel a slight vibration in the pedal and sometimes in the gear shifter...
            mine buzzes once in a while too, I thought it was my igntion but thankfully it wasnt.
              Mine does it in park most of the time but sometimes it does it in gear. For a while I thought it was my power steering pump but its not.
                GL's trans does it too in Park, sometimes it whines a little even though the fluid is full *shrug*
                  It's a hydraulic whine. At certain temps with certain pressures and certain transmission it will happen. It's nothing unusual or bad. Just an unforeseen resonating of fluid flowing under pressure.
                    Okay, good...I thought I had tranny problems...Thank God.
                      Both the towncar and vic buzz at various times.
                        our 88 LTC never buzzed when we had it...wierd.
                        although, it only had 78K on it when we bought it and about 95K on it when it got wrecked. poor Whitey...*sniff**sniff*
                          Not all of them do. And if it does, it doesn't usually stay that way for more than a month or two. I had one of my trannies do it for about 3 months then it went away.
                            Mine has been doing it off and on for almost a year. Not as much lately since it got real cold tho. My power steering pump has gotten really frickin loud on startup, but that goes away after about 5-10 seconds.
                              Mobil 1. Get a vacuum pump or something and change your power steering fluid.
                              I had my Mustang do the same thing, it had a loud pump when I got it. Changed the fluid out for Mobil 1 ATF and it became VERY quiet.
                              1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
