Originally posted by saiyaneye
Bigger Gas Tank...
Originally posted by saiyaneyeDid the 79's use a 20 gallon tank or am I just imagining?
Yes, so did 1980-1982 Sedans at least. I've got a 20 gallon.1990 Country Squire - under restoration
Originally posted by MeLikeyStripperChicksSorry man, but I didn't understand a word - how does shortening the filler neck increase the tank's capacity? Also what is that bag with hose and clamps, and how do you use it?
If the fill neck extends down into the tank more, it will cause fuel to back up into the neck once it hits the bottom of the filler neck because at that point air can't escape from the tank. The bag with the hose is just a different length rubber piece that goes onto the end of the steel filler neck so it extends different amounts into the tank. If you got a truck with the larger capacity fuel tank, all they'd do is pull the fill neck, remove whatever length piece was on there, and install the new, shorter hose on the end of the filler neck.86 Lincoln Town Car (Galactica).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by TiggieYes, so did 1980-1982 Sedans at least. I've got a 20 gallon.
Originally posted by saiyaneyeI have 18 gallon in my '81 Tiggie1990 Country Squire - under restoration
Originally posted by gadget73If the fill neck extends down into the tank more, it will cause fuel to back up into the neck once it hits the bottom of the filler neck because at that point air can't escape from the tank. The bag with the hose is just a different length rubber piece that goes onto the end of the steel filler neck so it extends different amounts into the tank. If you got a truck with the larger capacity fuel tank, all they'd do is pull the fill neck, remove whatever length piece was on there, and install the new, shorter hose on the end of the filler neck.
Should, yes. Not really sure if its worth the effort but thats a different argument.86 Lincoln Town Car (Galactica).
