I am thinking about getting a 97 explorer intake, is this year compatable with my HO conversion. I know I have to find a Lightning EGR and whatnot
97 Explorer intake work????
96 and early 97 intakes work......it must have internal egr
and you need a ford lightning egr spacer, or mod a mustang one......also need a 65 mm throttle body
the guy says its 97, I hope it has internal EGR, if it doesn't what can I do [besides sell it back] Scott - I'll be sending you a 65mm TB in the future for a towncar lever swapping if I do this.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
You can't see the EGR port on the upper in the pics, but if you flip it over, you'll see a smaller hole right in the middle where the two parts mate up. You can also see it on the neck as an oval opening on the bottom underneath the throttle bore.86 Lincoln Town Car (Galactica).
I'm currently getting an upper and lower, lower has injectors and rail and harness all attached for $190. Sound like a deal?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
deal if it has internal egr
Even if it doesnt, you can get away with it if you have an emissions connection. Probably wont pass for NOx without the EGR system.86 Lincoln Town Car (Galactica).
when did you get the exploder intakes Thaine??? good stuffPete ::::>>> resident LED addict and CFI defector LED bulb replacements
will my car run ok without EGR? I have no emissions inspection only safety, so its not an issue. I just heard it makes the car run rich or something when you disconnect the EGR1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
pete
gmgt donated his explorer intake for all gadgets help with the vic project
tom is going to use the typhoon upper and lower which i picked up on ebay a while ago
oh ok
89linc - Ive run without the EGR and havent noticed anything, but this was in the 85. Maybe a little different gas milage but I dont think it will run poorlyPete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 89LincolnTWNcarwill my car run ok without EGR? I have no emissions inspection only safety, so its not an issue. I just heard it makes the car run rich or something when you disconnect the EGR
Pete: what Scott said. I tend to not really bother telling people what I've got going on with my car. I just do it and update my sig unannounced86 Lincoln Town Car (Galactica).
I bought the intakes. they are being shipped to me for 189.99. Either way they are going on the Townstang. I think my transmission is starting to get old and quirky, so when that happens I'll be getting a heavier duty AOD with 4R70 wide gears....but not until it really breaks lol.
I'm planning on installing the Explorer intakes, lightning EGR, 65mmTB, BBK shorties, an electric fan, an underdrive pulley, and 1.7 roller rockers all at the same time. Will it be like a night an day difference in power? Or more of a small one.Last edited by 89LincolnTWNcar; 02-16-2007, 02:15 AM.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
