Hey mangs I have a problem. Last saturday I installed a new radiator so when I bled the system when puting new coolent in it. the coolent system will not build pressure. the car is at normal operationg temp 200 F and it won't pressure so my first though it would be that the thermastat is stuck closed. but when I drive the car it does not overheat then I thought I could be stuck open.
when I'm driving the temp guage goes from 187-215 it goes back and forth sometimes but will stay at 200. my question is do you think that there is still air in the system or the thermastat is stuck open or closed. I allready pressure tested the cap and the system there good. the weather has been in the teens around here so do you think that's why it's not overheating if the thermastat was stuck closed any info would help I really don't know what the problem is
