looking in to trans looking for the best for acceleration but maintain highway drving
Whats better C4 C6 or AOD
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
If you want to do any amount of highway, keep the AOD. That overdrive gear is a real life saver, allowing you to run plenty of axle ratio and still have it run slow on the highway. You don't get that with a C4 or C6.
keep the aod.....c4's were crap, and only 3 speeds....i have broken many lol......c6's are heavy and only have 3 speeds actually the aod is an overdrive version of the old ford fmx
Originally posted by 87_crown_vickeep the AOD but get better internals on it. make it into a heavy duty AOD. that way it can be used both ways, for fun, and cruisin down the road.88 Town Car (wrecked, for sale)
Originally posted by Blaze86VicKeep the AOD, and convert it to a wideratio.
If I didn't have my trans rebuilt when I bought my car 2 1/2 years ago, I would do the Wide Ratio gears right now.sigpic
Originally posted by lincolnmaniakeep the aod.....c4's were crap, and only 3 speeds....i have broken many lol......c6's are heavy and only have 3 speeds actually the aod is an overdrive version of the old ford fmx
For a street car an AOD is the best choice. A C4 does not have a lock up function in 3rd gear so it kills your gas mileage, that coupled with no OD, really kills fuel efficiencyhttp://secondhandracing.com/Home.aspx
C4's are tough. I couldn't kill mine. Had it behind 5 different motors and it had well over 200K. Neutral drops, 55mph WOT into reverse all the time. The only C4 I had that was a POS was the one from performance automatic.
For what you want to do ,a wide ratio AOD is the way to go.Builder/Owner of Badass Panther Wagons
C4+mods for a track car
c6 for trucks, especially stuff that doesn't see highway speeds normally.
AOD for a daily driver.
If you really want to get fancy and money is not a factor, use a 4R70w with a Baumanator stand alone shift controller. You'd need one from a 3.8 or 4.2L vehicle, or from a 5.0 Exploder. You get the wide ratio, all the upgrades that people move into the AOD, and complete adjustability of the shift points via the controller. Its a really slick setup, but its not cheap.Last edited by gadget73; 02-09-2007, 02:09 AM.86 Lincoln Town Car (Galactica).
