Problem! Help!
    Problem! Help!
    A little while back, when I replaced my PCV screen and cleaned up my IAC, I broke the little plastic thing that fastens the kickdown cable with the throttle.
    can I pick up a replacement at Advance or AutoZone or something? if so, what's that part called?
    I fastened it together with twist ties(as a temporary fix) and they came loose(of course).
    -Colin
    Isn't that the part that will fuck up your transmission in 3 miles if it's broken?
    1988 Mercury Grand Marquis
    Brakestand machine.
      uh oh...I hope not.
      either way, I need to get that part fast...whatever it's called.
        Go to Ford and get a brass replacement. I forget the part number, but thye should know what your are talking about when you ask for a TV bushing.
        YES it will screw your tranny if you drive it without the bushing.
          I can't get that part at advance/autozone/murrays/pep boys?
          BTW, I keep hearing the term "TV cable", what does the TV stand for? Throttle Valve?
            Info on the brass bushing here:
            This is a must-see site for fans of American luxury hot rods. Message forums, tech advice, news, and automotive performance links are offered for Lincoln Mark VIII and Mark VII, Lincoln LS, Town Car, Continental, Navigator, Aviator, Zephyr, MKR, MKS, MKZ and more.
              Yup
                thanks Nathan!
                ok...TV is Throttle Valve...
                and the part is called a Throttle Valve Bushing...cool.
                and the article shows the part number as F3SZ-7H303-B.
                thanks again!
                -Colin
                  No problem, mang. Glad I could help.
                    I called a local Ford dealer and they want 8 bucks for it!
                    for a piece of brass and a pin...WTF! rip off!
                    well, I suppose $8 is better than $1200 for a new tranny.
                      8 bucks is a cheap preventative measure. Lots of toasted AODs from that plastic POS failing.
                        yea, 8 bucks isn't a whole lot of cash...but the part is only a piece of brass the size of a nickel and a small pin!
                        it's prolly about 75cents worth of hardware...
                          yea just fords way of making money
                            I wouldn't be complaining about paying 8 bucks to save my transmission.
                            Brakestand machine.
                              Not knowing any better when I bought my 91, I fucked up that bushing when I had the upper off to do the valve cover gaskets and didnt replace it. I drove my car with a cotter pin holding the tv cable in the plate on the botton of the Throttle body from september 05-may 06, when I decided to replace it. Didnt blow up, didnt explode, didnt lose any gears suprisingly. Not advising this be done at all, just thought I'd share this info. go for the brass one, i asked for a new throttle valve grommet and they gave me a rubber one. I didnt know brass ones existed.
                              sigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
                              Vic's Reader's Rides Page http://www.grandmarq.net/vb/showthread.php?t=16917
                              Vic's Cardomain page http://www.cardomain.com/ride/2532949
                              1975 Chevy C-10 Cardomain http://www.cardomain.com/ride/3371894
