wonder what intakes are best for an efi can what throttle bodies are the best for each intake if an worked ho what should be done and are there better after market ones too
Wats better gt40 intake or cobra or a worked on stock ho efi
I think thats what he's doing here.
First off. GT40 and Cobra intakes both use the same lower intake manifold, just like the LOPO and HO use the same lower intake manifold.
Onward.
GT40 is the best of them all. An HO can be ported to match GT40 flow rates, but will be more expensive than just getting an GT40 Explorer intake. The tubular intake will save you some weight but are hard to find as well as being expensive.
There are also aftermarket options that are surprisingly competitive in pricing to the correct Explorer intakes. Those things have gotten expensive on ePay. The goal is mostly to match things up. A super flow intake with stock heads is not going to do anything useful, and on the same token having heads that flow huge amounts of air will not really perform unless the intake can provide them with sufficient flow figures.
so basicly what is best depends on what other parts and plans you have.86 Lincoln Town Car (Galactica).
Bang for the buck..... Explorer intake with modified Explorer throttle body and modified or Lightning EGR spacer.....
What does "best" matter if you do not have the money to build your car from front to rear? My point is to save money where you can yet still get excellent performance. That is why a complete Explorer motor usually makes the most sense. With a cam change it is good enough to push a Vic into the low 14's. at a minimum.
i have a full 2.25 exhaust will that work got it custom built and i have a set of after market headers from ebay not stock ones, how big should the throttle body be 60mm 65mm 70mm or 75mm what size injectors also ( i will be porting a set of gt40 heads hi flow )Last edited by 83countrysquire; 02-06-2007, 07:54 AM.sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
