my 250K mile lopo shortblock with cleaned up D9 heads (79 Lincoln Versailles) and stock HO intake, HO cam, 60mm TB, stock ecu and 19lb injectors put down 195.6hp. That with bad plugs, cap, rotor, melted plugwires, 87 octane and stock timing.Equal length shorties and 2.5" exhaust...
Which heads are better
Originally posted by mrltdmy 250K mile lopo shortblock with cleaned up D9 heads (79 Lincoln Versailles) and stock HO intake, HO cam, 60mm TB, stock ecu and 19lb injectors put down 195.6hp. That with bad plugs, cap, rotor, melted plugwires, 87 octane and stock timing.Equal length shorties and 2.5" exhaust...2012 Mazda5 Touring | Finally working on the LTD again!
