I'm thinking the car's developed a rod knock/lifter tap. Doesn't seem to do it at idle, cold or hot. Doesn't do it when I free rev. It only does it under a load at low RPM's, kick down to shift and it goes away.
Knock-Knock-Knock-Knock
it's common on 302's it will run a while like that........keep the oil clean and use a quart of lucas every oil change and you should be ok
scott
Re: Knock-Knock-Knock-Knock
Originally posted by IfixyawataI'm thinking the car's developed a rod knock/lifter tap. Doesn't seem to do it at idle, cold or hot. Doesn't do it when I free rev. It only does it under a load at low RPM's, kick down to shift and it goes away.
Originally posted by IfixyawataI'll get my timing light out and check, but the timing is set at whatever it was at when I got the car... it did it then too, before I tore it apart. So teh timing light will decide whether it's off or not.
Yesterday I changed the oil. 1qt Rislone (reccomendation by a friend, I had bougut it before I posted this) and 4.5 of Chevron Supreme 10w-40 (previous owner's oil of choice). And now the rattle seems more prevalant. I just hope if it's detonation that it won't lead to a HG failure anytime soon.
it could also be a noisey air pump. A reman air pump from NAPA for $35 fixed my knocking noise.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
we had to put 2 reman pumps on the lincoln and it still isent right. i have a ford one im gonna put on.
Have you switched to premium fuel yet? Wait until your tank gets low, or it will be diluted. Pulling the belt on the smog pump will definitely rule that out, but I really don't expect that to be it. I have to run premium in my car with its dying engine or it pings.
