I have it all along just haven't figured out the problem, could it be the tv cable it shifts at like 6-7 rpm
Late Shift from my AOD between 1-2nd
Same symptoms as mine. I adjusted the TV Rod and now it's like butter.
Here is the link I used for specific instructions, there is also a sticky on this.
"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
You might want to get this fixed because you'll soon blow rods out if you keep winding her to 6-7K.1990 Country Squire - under restoration
Originally posted by TiggieYou might want to get this fixed because you'll soon blow rods out if you keep winding her to 6-7K.Builder/Owner of Badass Panther Wagons
Originally posted by mrltdThere is NO WAY in hell he is turning 6-7K on that motor. 4500-5K on a lopo sounds like it's gonna grenade, and with the cam, heads, and springs it's pretty much impossible.Nick
88 Colony Park LS
