Green crap ^_^
    Green crap ^_^
    Ok, so i noticed today under my car was some green liquid shit... This happend whille it was running, cause it wasent there before i turned it on. but i coldent locate where it was coming from...
    Now normaly i would say radeator leak but.... My anti freeze isnt green it's piss yellow so what could it be?
    Trany fluid is red. and oil is black..
    maybie the Flux capaciter
      Was green antifreeze in there at any point? If so, maybe not all of it was drained out before the yellow antifreeze was added.
        It never had anti freeze before i owned it.. :-(
        To weired.. Well, it did fall from around the harmonic balancer.
          Has your ac been recharged? it might be the freeon in the ac system
            Nope... I did think that though.. Maybey it' still got freeon in it :-D Ill salvage what i can and sell it :-D Muhahahaha
              Freon would be in a gas form anyway unless it's like -50 where you live.
              Taste it to see if it's sweet. Just kidding, it's highly toxic! Does it smell sweet, and is it kind of sticky when it dries? That means it almost is certainly antifreeze. I put pee green antifreeze in my Ranger, but it turned green from what was still in the heater core and block.
                is your coolant yellow from lack of maintinance? it could still look greenish as hanging droplets. If its under you balancer you prolly need a water pump, t-stat gasket or one of the hoses there is leaking.
                  It's yellow due to umm thats the colore of the collanet at napaer...
                    If its from around the balancer, I'd bet its either a lower radiator hose leaking at the water pump, the water pump leaking from the weep holes, or the backing plate for the water pump rotted and leaking down between the pump and timing cover. Its almost certainly antifreeze, nothing else in that area could be that color. If in doubt, taste it. If its sweet and has an oily/sticky feel on your fingers, its antifreeze.
                      I am not by no means tasting antifreeze..... shit's to poisones.. :-/
                      Im leaking something else now as well after tonight something leaking fast... i woldent be surprised if what ever it is is drained all the way by the AM....
                        were you slimed?
                          wacta mean slimed... it looked like a slug been crawling where ever the car went... and when we got back no more..
                            gadgets right thats what happend to me
                              How hard of a fix is it?
