Bouncing Oil Pressure
    Ever since I've put a mechanical gauge in this car, it has had low oil pressure. I figured since the motor is pretty nasty inside with 124K.
    The other day I noticed my oil pressure at warm idle idle fluctuates. The needle bounces between 10 and 15psi. If you put a little load on the motor, it stabilizes. Is the gauge bad or is this normal with a worn motor?
    Here is a video: Linky. It's about 3.5MB.
    Also, I can be cruising at 55mph in OD on the gas and I'll have about 22 psi. I let off the gas and the oil pressure shoots up to 40psi. Back on the gas, it comes back down within 3 seconds to 22psi. It will do this all day if you wanted it to. Is this normal with a worn motor? In drive it doesn't do it as much, but there is still a little variance.
    Ideas? Not that it really matters, I was just wondering. This motor is coming out this spring hopefully.
    yup worn bearings cause that. They'll run with much less pressure for a loong time. Not something to really worry about.
      Perfect example of what happens when the mains are loose. Under coasting conditions, bearing pressures shoot up, so oil pressure increases. Even in an engine in good condition, you can see a slight difference (2-3 psi), but if you're going from 22-40, I'd say they're quite loose.
        mine bounces between 15 and 25 on my electric one
          Keep driving
            Keep driving
            I will .
              I had a yard vehicle at the junk yard,(I used to carry my toold and torches etc) with no oil pressure and it ran for months, the engine dident sound to helthy but it still ran,, the only reson it died was beacuse of an electrical problem,
                keep driving
