Hello all Im new here and have a question. I already tried the search and could not come up with anything. I have a 83 Grand Marquis 5 liter EFI the car will stall everytime I take my foot off the gas but will run fine when I give it gas. I think the IAC valve is the problem but I cant find it. Can anyone tell me where it is or what else the problem might be. Thanks for the help.
83 Grand Marquis
If it is an 83 than it is a CFI car not EFI. I dont think the CFIs use a IAC valve. 85cvhpp* is the resident CFI guy.http://secondhandracing.com/Home.aspx
If the car hasnt been serviced for a while Id check the EGR valve first, its probably clogged holding it open. Its supposed to be open while you drive, but you cant idle too well with it open.
I had a link to an excellent writeup on how to clean CFI EGR but it was on OldSchool's page and its down now...Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP*If the car hasnt been serviced for a while Id check the EGR valve first, its probably clogged holding it open. Its supposed to be open while you drive, but you cant idle too well with it open.
Originally posted by fomoco01Hey its nice to see a fellow Hoosier. Im only familiar with EFI 5.0s(and not an expert by no means) but thats what my 89 & 91 both did the same thing and I was EGR issues. You get good at left foot braking though.
So there is no IAC valve on a 83? That would explain why I cound not find it.
There should be a dashpot that sits against the throttle lever to push it open for high idle, but no IAC like on a newer car.86 Lincoln Town Car (Galactica).
