But not into second until 40 MPH, into third at 60. I've had the TV rod adjusted all the way out, all the way in, no change. The bushing at the transmission rod has some play in it. Anyone know the number for the bushing? Anyone have other ideas to try to get the shift range more normal?
At least it shifts now....
"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
Tags: None
does it go into overdrive?
I haven't had it that fast yet (only test driving on county roads) but I will try it out tomorrow"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
It DOES shift into Overdrive, but pops back out. Then goes in and out. I actually took the time to trace the rod down to the transmission and found that it is NOT what I adjusted yesterday. I'm not used to the older boxes anymore.... I am going to adjust the PROPER thing tomorrow after work tomorrow, but what other idea did you have Scott?"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
make sure the tv rod is hooked up to the throttle linkage on the cfi unit
It is and there is a red plastic bushing in the rod and it's all held on by a cotter pin. I have to get under the car tomorrow to adjust the rod at the transmission and hopefully that takes care of it. There isn't a vacuum modulator on these like the way older ones is there?"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
No vacuum modulator on AOD's.
The TV control pressure is almost certainly out of wack. It definitly wouldn't hurt to take it to a tranny shop and get them to check the pressure with a gauge. It's not nessarily the adjustment causing the problem. Is there any binding in the linkage that would be causing the rod not to return to it's beginning position? How about the return spring, is it there and operating properly? You also might want to check to see if there is any evidence of the rod being bent.
If the TV pressure is fine, you'll want to look into other areas. Was the tranny fluid pretty nasty? If so, it could have caused the governor to be sticking, or your valve body could have some sticking valves. Believe it or not, a valve body that is slightly loose from the transmission could be causing these problems. I know you've checked the fluid level, but I'll mention it for future reference of others.1990 Country Squire - under restoration
I got under the car tonight and found that my little Brother never tightened the adjuster bolt on the TV Rod. After three adjustments (to get the right shift feel) it now shifts better than my 96 with the J-mod. What a pain in the arse to adjust that rod under the car. Glad it's done and shifting well!"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
