Surging while driving and coasting
    Just to add to all the other shit that has been going wrong with GL lately. The engine is starting to surge, I can feel it while driving, it's really noticeable while coasting though. I want to fix it for now, but I've had enough of this carburator bullshit. I'm gonna start pricing EFI shit to swap in. The plugs and wires don't have that many miles on them (I've put maybe 5,000 miles on GL since I did the carb swap) so could it be a carb or electrical problem or something?
    hmm, while coasting? Does it by chance stop if you put it in D or shift to N ? Could be maybe the lockup in the trans makes it feel like something is wrong. If its the lockup torque converter, and you have a bad trans mount, it will float and bang around, causing some strange feeling stuff. Under power, hard to say without knowing more. Does this happen at cruise, or under acceleration or what?
      You can feel it when you're cruising, but it's more pronounced when I'm coasting though. I have noticed lately that when I'm at a stoplight, the engine likes to wander around a little bit, I can see the tach needle move up and down some. Also, sometimes even when the engine is completely warmed up, and I stop at a stoplight, the engine tries to die or runs like shit. I have to put it in neutral and rev it up to keep it running. But it doesn't do it all the time, other times in the morning it runs great. I don't understand the inconsistancy here.
        LOL, pricing EFI? Fix the damn carb. You do not want to deal with trying to get an EFI to run right and trace problems....
        I've replaced everything on my car and it still doesn't come close to running decently. Misses, bucks, surges.
          FUCK carb lol
          If I'm gonna get anything, it's gonna be Holley ProJection
            we don't seem to have any problems *knock on wood* with EFI but my jeep stumbles and wonders around like that and its all because of the carb stupid motercraft carb not working right...
              Carbs and EFI can run just as fucked up. Trust me, I've seen some horrible running carb engines just as much as I've seen horrible running EFI engines. Carbs are more picky about maintenance though, neglected EFI isn't quite so bitchy as a neglected carb.
                You can tune a carb yourself, as opposed to not being able to tune an EFI system yourself without proper equipment. Am I right or wrong?
                  I just have to Buy a compleatly new carb.
                    Mostly true, but it still needs a few things and knowlege. It also depends on everything else working properly. You can be a god with a carb, but if the carb is shot, its just going to run like crap untill its repaired or replaced. Emissions stuff on a carb motor can also be a disaster. Half the time its broken, missing, improperly removed, or has any number of other problems to deal with, and that can really play havoc. The work truck at the marina I used to work at had butchered smog controls, and it would backfire and shoot fireballs out of the tailpipe. I ripped all the parts off, and it stopped running retarded.
                      Holley double pumper 750 for my jeep........I wish
                        Unneccesary. Unless its a big displacement motor with a fair amount of cam and head work, it wont need that much. A stock 460 can be fed properly with a 650 cfm carb. Big carb on a stock motor just wastes fuel, it does not produce any more power.
                          Gadget, by chance how do you fix that stuff :-D I think that might be whats wrong with mine bangs around down there and gets under powered...
                          Sorry to jack the tread just got a bit excited to hear what might be wrong with mine :-P
                            What carb is on GL?
                              2150 2bbl, I believe?
