i know the 351c was used late 69-74.........351m 75-81, and 400 71-81
Cleveland motor
If it IS a C, and you want EFI, this can be FUN!
You'll want a single plane intake for it, get injector bungs welded in the runners so you can run EFI rails on it, then pick up an elbow from CHP to mount where the carb would go. From there, you run a standard Mustang-style throttle body.
You might have to do something funky with the distributor.........
Convert the bad boy to roller with crane link-bar lifters, and run a custom camYowzah! It'd be quite the weapon!
1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by lincolnmaniai know the 351c was used late 69-74.........
Originally posted by Roach IIIWell, I'll check next time I get down there in the light. If it's 351M/400, I'm not going to mess with it. A 10.3" deck height is way too much motor for Fire And Ice.Nick
88 Colony Park LS
It would be cool to pull stumps out with the TC!Project \"Fire and Ice\":
1989 LTC
My worst enemies are those who presume me to be harmless. They cannot imagine how much I resent and disdain them, or just how great a threat they would face if I could get at them. Everything in their behavior speaks of insult and presumptuousness, and for now it is all I can do to make constructive use of my anger toward them. At this time, I just make a list of them and keep a watch on. Some day, with the help of time, space, and circumstance, I will be able to humiliate them properly - not in a manner they would enjoy, but in a style calculated to make them wish that they had never been born.
Anton Szandor LaVey
Originally posted by turbo2256bAs the owner of both a basicly stock 460 in a dually and a 375 horse 400 in a 4x4 if I had to purchase an engine for the 4x4 I would go 460.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Are the deck heights actually different between a 351M and a 351C ? I know the heads and cam interchange, but I know little about these motors. I seem to recall reading that the intakes interchange too, which would (at least to me) mean that the deck height is not different.86 Lincoln Town Car (Galactica).
yes a 351m is a destroked 400 block
Originally posted by 88MercWagonPersonally, I think a carbed 400M swap would be a better idea than a 351C. With head work and a cam, a 400 can be a real screamer, and have stump-pulling low end torque. Just ask MRLTD about the 400 in his Bronco.It is kind of like guys that say nos as a word when talking about a nitrous system. Yes, it is common slang in some circles, but it just isn't right...
A 400 is definitely a potent moter when built right. 400+ cubes and Cleveland heads is a great combination. There wouldn't be 400+ cube Clevors if it wasn't. You just need to sonic check your block as all 335 series blocks (351C/351M/400) are subject to very thin walls. It doesn't take much of a cam to make over 400HP at low rpms. If you are going to do it, you might as well bolt on 351C 4V heads and use a 351C 4V intake with the adapter. You will need custom headers either way and a double hump oil pan.
Originally posted by gadget73I seem to recall reading that the intakes interchange too, which would (at least to me) mean that the deck height is not different.
Deck heights according to wikipedia:
http://en.wikipedia.org/wiki/Ford_335_engine
351C is 9.206 in.
351M/400 is 10.297 in.
the 351M was a destroked 400 with a 351W crankshaft.Last edited by Roach III; 12-24-2006, 10:03 PM.Project \"Fire and Ice\":
1989 LTC
Anton Szandor LaVey
351C is 9.206 in.
the 351M was a destroked 400 with a 351W crankshaft.Last edited by JeffBoudah; 12-24-2006, 10:33 PM.
