How to disconnect stock tranny cooler line?
    how mangs I was woundering how you disconnect the stock tranny cooler line comming from the cooler Its starting to leak here's a pic of it thanks mangs
    Cut off the crimp and put a hoseclamp on it. Those aren't removable (and/or reusable) .
      What he said. One time things those are.
        what they said, also replace the 18 year old hose
          I will scott I replaced the power steering cooler line's in sept it's the tranny line's turn to be replaced
            I used an air grinder with a cutoff wheel on mine. Same thing, leaky hard-as-rock lines.
              Don't use a grinder or a saw. Use a pipe cutter. Both grinding and sawing can cause metal shaving to get into the pipe and then maybe the tranny. Don't want that.
                I just replaced the intire thing*shrug*
                  If you just cut through the outer metal band and not into the tubing, its not an issue.
                    Good point.
                      WTF is that shit?! I never saw that before..
                      '95 Ford Bronco XL -
                      sigpic :rebel:
                        its the stock tranny return cooler line
                          That can't be stock. I've never anything like that...
                          sigpic :rebel:
                            umm,hopefully ure trany has a return cooler line mang.. )
                              How many of your cars had the towing package Jeremy?
