Will removing air injection cause any problems??????
    This isn't a Panther question but it is a 5.8L question. I picked up a 4x4 with a bad motor(5.8L ) so I'm swapping in a good engine out of my other F250(also a 5.8L ). They both have the air injection in the exhaust manifolds and many hard lines and hoses all over the engine. Will removing the airpump/air injection cause any problems? I have to change the valve cover gaskets so I have to remove all the crap anyways.
    no problems, just will set a code for the air pump system, will not cause any adverse driveability problems.........ditched tons of the dual smog pump setups on 351 trucks for the stiped airtubes to the manifolds rotted out
      Thanks Scott, that's what I was hoping. That air injection setup is a mess!! yanking all that crap will really clean up the engine. Not to mention make it easier to work on.
        My car doesnt have it. May make it ping under heavy load a little. But not enough to hurt anything.
        1989 Grand Marquis LS
          How does injecting air into the exhaust manifold keep it from pinging?
            Also pumps it into the heads, allowing them to run cooler. Cooler temps=less pinging.
              most smallblocks with the air passages in the heads that i tear down are clogged shut.......no pinging on any of my fleet......lincoln timing is set at 16deg........89 vic 12 deg.....neither have a smog pump, no pinging under heavy load
                My car is set at 10 and pings under really heavy load. But uh, my loads are bigger than yours.
                  This is going in a truck that weighs 6,000-6,500 pounds and will be pulling loads up to 8500 pounds. The cat is rusted thru so it's getting chucked along with the stock muffler. I've got a pair of 2 1/2" Hooker aerochamber mufflers I'm going to run. I really want to get rid of all the air injection crap.
                  Way too much crap on this motor!!
                    351 smog controls are horrible. Waaaay too much BS on them. The carb engines are worse though. I had to work on an 87 4bbl 351, dual smog pumps and about a mile of vacuum hose. It had been screwed with, and it would blow fireballs and black clouds out of the exhaust. I ripped all that BS off and it ran much better.
