Im wondering if i put a set of stock HO headers on my merc if they will bolt on to my original exhust without much or any modification??
stock HO headers bolt right in?
depends what you consider not much. Can you weld.? Would you consider welding 2-1/4" collectors to your stock converters a big project or a little project.?
In other words. Mustang pipes are 2-1/4", stock lo-po's are 2".1987 Country Squire LX Wagon 5.0L: Daily Ride......1964 Lincoln Continental 430ci: Toy #1.
Might need new bolts for attaching them to the head, not sure.1990 Country Squire - under restoration
If you're replacing the H pipe, its easy. Yes, need different bolts but thats it. Actually the short bolts from the manifold are the correct ones, but might as well install all new. I would also suggest using lock washers. No need for special header bolts either, there is plenty of room around the stock headers for a regular socket on a normal size bolt.86 Lincoln Town Car (Galactica).
