Hey 2 more days untill my intake gaskets change I was woundering what sizes vaccum hoses are connected to the intake I'm going shooping at advance tommorow for the rest of the stuff thanks mangs
what size vaccum hoses for intake?
I just had to remove my upper intake to replace the vacuum hose to the MAP sensor. I had bought some hose before hand and it was the wrong size. Take the hose with you to the store to make sure you get the right size. Note any difference in size at the end that slips over the nipple. Removing and replacing the upper intake was much easier than I suspected. Careful not to lose your TV grommet. Have fun.
I would just buy a variety... you might need other sizes later onPete ::::>>> resident LED addict and CFI defector LED bulb replacements
I am unsure as to the size of the vaccum lines going to the MAP sensor and PCV valve. If I were to guess i would assume 1/2", 3/8", 7/16" 1/4"
ooh btw, windshield washer tubing (rubber kind) works great if u plan on replacing the (HARD COLORED PLASTIC) going to the fuel pressure regulator and egr valve and such.....
Hope things are going well.... Take pics, and keep us updated!1987 MGM 126K 2" True Duel flowmaster 40's 3" tipped exhuast, Tinted 20% all way round, individual bank A/F guages, tach.
thanks mike I hope so to I hope I got everything theres a pep boys advance and car quest If I need anything
PCV is 3/8" fuel line, I think the MAP is like 1/4 inch or something. Might be best off taking the upper intake off, pulling the lines and getting a ride to make sure you get the right sizes.86 Lincoln Town Car (Galactica).
me and mike manged not to brake any vaccum lines at all
They weren't ready to fall apart on thier own? wow. Whenever I've pulled one apart the line for the MAP sensor was always brittle and ready to crumble from touching it.86 Lincoln Town Car (Galactica).
