I finally did it. I've been sitting on these parts for about a year. I had to replace the leaking valve cover gaskets. While I was in there, I figured I might as well replace the intake. It's 90% complete. I have a GT40 upper with a Tmoss ported GT40 lower, 67mm Ford Lightning EGR and soon to be mounted 65mm Explorer TB with a CV throttle arm. The Explorer TB has a different TPS location than the Panthers and Fox boxes. I had to order a TPS for an Explorer and bolt the 50mm TB back on until the part comes in. (The Lightning EGR fit like a glove). I also have to lengthen the ACT sensor wires to mount it in the intake tube.
Now I have to save up for a 347 cu in. stroker motor and race-built AOD.
