Plug them.
heatercore?
Originally posted by gadget73 View PostI had one of those on my car for about 2 weeks before it exploded and caused the engine to overheat. That ended my attempts with Four Seasons parts. You can replace it if you'd like, but for durability and simplicity, its hard to beat just getting rid of it.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
Originally posted by 87gtVIC View PostPlug them.)!
I was just thinking about that TBL...replacing it with a flush-T for a coolant flush (like Prestone's flush and fill kit) might make sense. No hose cutting required. I wonder if the space is too big though...1990 LTD Crown Victoria LX. As stock as the day it was born.
16" HPPs sitting in the garage. That's it for now...kids gotta eat.
I replaced my TBL with a plastic hose connector, which is pretty much the same dimensions as one of those flush tees. I see no reason why one of those wouldn't work in that spot.
Small ball bearings work as a neat way to seal off those vacuum lines. Put a dab of RTV in the end of the line, stuff the ball bearing in there, and leave it be. Most good hardware stores will sell the balls for like a quarter each. Not sure what size you'd need though, maybre 3/16" or 7/32".86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI replaced my TBL with a plastic hose connector, which is pretty much the same dimensions as one of those flush tees. I see no reason why one of those wouldn't work in that spot.
Great idea about the bearings for plugging those vacuum lines.1990 LTD Crown Victoria LX. As stock as the day it was born.
I'm hopping on the plugthedamnthing bandwagon too.
Originally posted by erocksteady View PostAnd the TBL is on the intake line for the heater right? I guess I could walk my lazy ass outside and look, but I believe it's the one coming from on top of the intake near the thermostat.
Great idea about the bearings for plugging those vacuum lines.86 Lincoln Town Car (Galactica).
So yesterday I ripped out the TBL and replaced it with a coolant flush tee. Fit perfectly! I didn't have any ball bearings, so I actually stuffed ear plugs in the vacuum holes, then wrapped the whole thing up in tape. Seems pretty air tight now...don't know abou the longevity of ear plugs though, haha. Works well, no leaks, and I have floor heat!1990 LTD Crown Victoria LX. As stock as the day it was born.
large machine screws dipped in RTV are also pretty effective. I think a #12 or maybe a 1/4" ought to do the job.86 Lincoln Town Car (Galactica).
Golf tees work well too.Originally posted by gadget73There is nothing more permanent than a temporary fix.
You will want to loosen up the dash as you need just that extra bit of space to get the plenum out. I didn't disonnect it entirely, I loosened the drivers side, removed the bolts on the passenger side and wedged a 2x4 between the door frame and dash to hold it back.
1987LTDmasta claims he did his heater core by shoving the entire dash slightly up. I have yet to figure out how he did that. I always pull the entire dash out, and yes, dropping the business end of the steering column makes that lots easier. Lots of room that way. I've got pics around here somewhere .....2012 Mazda5 Touring | Finally working on the LTD again!
i do too i had the lovley fun of replacing mine last year
http://www.grandmarq.net/vb/showthread.php?t=3140689 townie, mild exhuast up grades, soon to have loud ass stereo....
