probably a bad mount. I've had that issue on more than a few cars. replace the trans mount on the crossmember and the buzzing goes away.
transmission making buzzing noise in park
Trans works just fine, as well. Does it have just the one mount on the crossmember?
How impossible is replacing it by yourself with the trans still installed?Last edited by 1990LTD; 03-30-2011, 02:30 PM.sigpic
Sounds like the furnace in my house. There is a transformer in it that buzzes all the time. When the tech was out I mentioned it to him and said, "they all do it" When I wanted it fixed he asked "why?" Five years later it still buzzes.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by 1990LTD View PostTrans works just fine, as well. Does it have just the one mount on the crossmember?
ETA my car does it for a few seconds after you put it in park, then the idle settles down some and it goes away.Originally posted by gadget73There is nothing more permanent than a temporary fix.
ok... forget my reply. I missed the "in park" part. If it was the trans mount, it would be worse in drive.
First I have heard of this. Now you guys are going to make me listen for it.~David~
Originally posted by slymer View Postok... forget my reply. I missed the "in park" part. If it was the trans mount, it would be worse in drive.sigpic
Originally posted by 91waggin View PostJust one mount on the cross member. Support the tailshaft with a jack; make sure you put a block of wood between the transmission tailshaft and the jack. Unbolt the mount, install new one. Easy to do alone.
