I just picked up an old 8.8 rear end for free. The durms are rusted on tight. So I pulled the cover off the pumpkin, It doesnt have the S spring so im thinkin its a open diff. But I would like to know what gear it has in it. Its missing the tag but i got some writing off the ring gear. It reads, Ford USA D9LW 4210 EA2352. Ive searched this part number with no luck. So im throwing it up to you guys. Any help or advice would be awsome. Thanks
8.8 Ring & Pinion
8.8 Ring & Pinion
Stock 91 Merc GM GS 5.0L EFI, AOD, 2.73 Open diff
Current Best 1/4 Mile 17.175 = 165 RWHP 190 Engine HP
http://www.supermotors.net/vehicles/registry/15193Tags: None
Can you get the info off the tag that should have been attached to the differential cover? That would have the info you want.86 Lincoln Town Car (Galactica).
the pinion gear has the gear ratio on it.....yes the tag on the axle cover tells you the ratio also
Originally posted by lincolnmaniathe pinion gear has the gear ratio on it.....yes the tag on the axle cover tells you the ratio alsoStock 91 Merc GM GS 5.0L EFI, AOD, 2.73 Open diff
