I gapped my plugs at .050 when the sticker under the hood says .042-.046?
Would it be a huge deal if...
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I gapped my plugs to .050 and it's fine. As long as your spark system is up to it, (I'm assuming yours is the Duraspark since you have the same car as I do, which in that case it certainly is) you'll have better spark with a bigger gap.
Should be within specs, but its not the end of the world. Might run a little better gapped correctly but you're not gonna blow anything up.86 Lincoln Town Car (Galactica).
I was meaning to ask about the coil at some point. Things work pretty good gapped at .050 but I was planning on pulling the plugs just to check the new set anyway so Ill prolly end up regapping them. Thanks.
I car recommends .050 anyway and I have the Duraspark just like you guys.1990 Country Squire - under restoration
I knew a guy who's engine was decked and shaved so much that the pistons would smash the gap closed if he didnt intall them with the electrode up.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by Fordman75A 89 and a 91 doesn't have a Duraspark ignition system. It would have a TFI distributor/module.
Both Nathan and 91 LTD have 351W, therefore the Duraspark I beleive.1990 Country Squire - under restoration
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by TiggieBoth Nathan and 91 LTD have 351W, therefore the Duraspark I beleive.
Originally posted by LtMercDaddyI have heard that some power increase can be made with indexing the spark plug with the electrode pointed up towards the valves....Scars are tatoos of the fearless
