Originally posted by 89LincolnTWNcar
Turbo 5.0
instead of expensively and painstakingly tuning the computer, could you not use an AFC hack device, or an FMU to manage air to fuel ratios? I was working on a turbo 1988 acura integra using an APEXi air/fuel controller and it worked great, cheap too.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by 89LincolnTWNcarinstead of expensively and painstakingly tuning the computer, could you not use an AFC hack device, or an FMU to manage air to fuel ratios? I was working on a turbo 1988 acura integra using an APEXi air/fuel controller and it worked great, cheap too.
yeah we upgraded the injectors on the integra too, 450cc instead of 2** stock, and popped on the turbo apparatus, and all that was needed was a bigger fuel pump and that APEXi air/fuel hacker. 180whp in a 2100lb car = fun1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
how much are they, and do they work with ford eec? hmmm....ricer parts on a ford lol
I'm gonna use the Megasquirt v2 on my car. It has no MAF to mess with, Wide band O2 A/F controll, can use high or low impedance fuel injectors, can use cheaper GM sensors. Also you can control all of your ignition timing and I can use the EDIS-8 No distributor!!! and it even has a rev limiting feature. Its really inexpensive too, around $245 for the kit.
they are around $250 and they work with any EEEC I'm pretty sure. It just tricks the ECU into adding more fuel via the MAP sensor. It works best on vacuum advance engines which is also good.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by mrltdyou can do it with all the stock components (except for the fuel system), it just will be very sensitive to any error in tuning. For turbo 5.0 info search turbomustangs.comScars are tatoos of the fearless
There are ways to do boost with speed density. I don't know for certain how different it is, but I know there was a KB supercharger system for 86-88 Mustangs that did not use mass air. There is a guy on LoL who has a stock Mark VII motor and ECM with a KB running speed density at like 6 psi or something. Not certain there isn't a tune involved with the ECM but I do know it does not have mass air. I imagine if a supercharger can be made to work with it a turbocharger could be fitted in a similar manner.86 Lincoln Town Car (Galactica).
Originally posted by gadget73There are ways to do boost with speed density. I don't know for certain how different it is, but I know there was a KB supercharger system for 86-88 Mustangs that did not use mass air. There is a guy on LoL who has a stock Mark VII motor and ECM with a KB running speed density at like 6 psi or something. Not certain there isn't a tune involved with the ECM but I do know it does not have mass air. I imagine if a supercharger can be made to work with it a turbocharger could be fitted in a similar manner.Stock 91 Merc GM GS 5.0L EFI, AOD, 2.73 Open diff
Current Best 1/4 Mile 17.175 = 165 RWHP 190 Engine HP
http://www.supermotors.net/vehicles/registry/15193
A chip tune would be all that is needed to keep the SD setup.
2 255's and 42's? For 400+ HP maybe. You will not see that with a turbo'd lopo. Seriously, go search around turbomustangs for all the info you'll need.Builder/Owner of Badass Panther Wagons
I dont want to even compute the brainpower into reasoning why u would want to turbo, better yet TWIN turbo a marine engine? most marine equipment run with a consistant rpm..... (ie crusing) then comes the cooling of the inlet charge automobiles use ambient air threw a front mounted intercooler in most cases, im sure there could be some adaptation of a watercooled intercooler as im sure the block is cooled with water is in as most marine engines are
nevermind, a second look at u can see its running open inlet turbos.... duh
thats gotta be one bad ass boat on accelleration
is it running a stern drive? or fully inboard propultion?Last edited by LtMercDaddy; 10-31-2006, 11:49 AM.1987 MGM 126K 2" True Duel flowmaster 40's 3" tipped exhuast, Tinted 20% all way round, individual bank A/F guages, tach.
Originally posted by LtMercDaddyI dont want to even compute the brainpower into reasoning why u would want to turbo, better yet TWIN turbo a marine engine? most marine equipment run with a consistant rpm..... (ie crusing) then comes the cooling of the inlet charge automobiles use ambient air threw a front mounted intercooler in most cases, im sure there could be some adaptation of a watercooled intercooler as im sure the block is cooled with water is in as most marine engines are
is it running a stern drive? or fully inboard propultion?Builder/Owner of Badass Panther Wagons
