Im wondering if there is a way to adjust my vaccume advance on my distributor to get more preformence, and if it is adjustible how and whats the best was to do it?
Vacuume advance adjusting??
Might want to check out this: http://www.grandmarq.net/vb/showthre...ight=duraspark
You are running a Duraspark Setup, right?1990 Country Squire - under restoration
Theres some that have an allen bit inside the nipple for the vaccum hose you use to adjust it. I think it takes a 3/32 allen key. My reman dizzy doest have it. :shrug:
your performance would mosty be affected by adjusting your mechanical advance, advance curve, and the intial and total timing you have. Vac advance only works during part throttle cruising.
heres an awesome article on how to mod your dizzy for performance
