Is there a underdrive pulley kit available for these cars? All I can find is kits for the mustangs, which are a single belt set-up. If theres none directly made for our cars, is there another kit that would be interchangeable?
Underdrive Pulleys
A.K.A Kaptain Kanuck, Your Connection To The Great Land Of Eternal Winter and Incredibly Rusty Cars
- Oct 2006
- 2083
- Ontario
- Send PM
Underdrive Pulleys
sigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
Vic's Reader's Rides Page http://www.grandmarq.net/vb/showthread.php?t=16917
Vic's Cardomain page http://www.cardomain.com/ride/2532949
1975 Chevy C-10 Cardomain http://www.cardomain.com/ride/3371894Tags: None
Yea this is for the crank thats the crank thats about the only UD Pulley i know of for our cars. here the link
The Best
- Oct 2006
- 2083
- Ontario
- Send PM
When you change that crank pulley, is the size decreased so much that you can no longer use the stock belts? Or is there enough play left over to adjust the extra slack outta the belts?sigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
https://www.aspracing.com/ezRetail/s...php?msg_id=212
Make me an offer, I won't be insulted. I'll get a picture soon, too.
~Adam
'85 2-Door Crown Victoria
302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
'04 Crown Victoria LX Sport, '02 Jeep Liberty
'83 Suzuki GS 1100E Motorcycle[/color]
Originally posted by NATEHAWKYea this is for the crank thats the crank thats about the only UD Pulley i know of for our cars. here the link
Originally posted by MeLikeyStripperChicksDaaamn, $125? Add the belts to that... not in my budget unfortunately, otherwise I'd all over it.
Yup, but if you're running an HO or something insane like me, you NEED it.Builder/Owner of Badass Panther Wagons
- Oct 2006
- 2083
- Ontario
- Send PM
Thats not that bad. And they kinda got ya by the nutz if they are the only manufacturer of a pulley specific for our cars. I'd rather spend that and get new belts then screw around with a comple mustang accessory change-over. If i switch to that pulley, what belts should I be lookin at gettinsigpicVic Videos Here http://www.grandmarq.net/vb/showthre...676#post243676
Originally posted by mrltdYup, but if you're running an HO or something insane like me, you NEED it.
On a non-HO, probably not much. And yeah, for HO engines it's because fo the much higher RPM that they reach. I blew every single hose off my old car, melted alternators, and bent alternator fins because of over revving the accessories.Builder/Owner of Badass Panther Wagons
