I noticed like the last 2 morings after I start the car before I put in gear. the car is idleing its acting like it wants to stall. I have to have me foot on the pedal a tinny bit so it does not stall do you think it's from the cold it was 38 this moring.
the engine has 155,400 it just started a rod knock the knock is not too bad just on start up. do you think because of the knock it would want to stall after start up? I take care of the engine or is it iginition parts? any info would be great.
thanks mangs
ps this problem only happens on startup it does not do it when I drive it
thanks mangs
