Originally posted by DuceAnAHalf
EFI 351?
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by Nathan in MNCan you explain what you mean? I'm not sure I understand.
This but with a shorter dual plane intake.
Price is a big draw back if you get one of their kits. They run about $800, i believe you can pick up the elbow alone for under $100, then you would need an intake and then have it machined to accept the fuel rails.
These set-ups have the potential to produce some insane power. Take a look at any fast SBF drag cars. The majority will be using a set up like this.http://secondhandracing.com/Home.aspx
Thats what I plan to have for my "hot rod" box... a wicked EFI 351 with aftermarker induction like that. Hell why not a supercharger too.
My old boss does welding and metal fabbing so Id get him to cut and raise the upper part of the hood like Scott used to have photochopped in his sig.
(one day....)
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
COOL! So then I could basically use the 4 bbl intake of my choice, put the elbow on there, mount the throttle body on the elbow, and go?
Originally posted by Nathan in MNCOOL! So then I could basically use the 4 bbl intake of my choice, put the elbow on there, mount the throttle body on the elbow, and go?http://secondhandracing.com/Home.aspx
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by DuceAnAHalfYup. Just gottta get the intake drilled for the fuel rails.
Originally posted by Nathan in MNSo is that something I would have to have professionally done or could I manage it with a drill press and a set of pipe taps?
Just have to make sure you get the spacing and angle right. Also the injectors dont use NPT fittings they just use o-rings. Would be best to find an intake that has nitrous bosses in it so that there is little more meat there for stability.http://secondhandracing.com/Home.aspx
It will require welding too...not just drilling. You need to weld injector bungs in it for the best results.
As for hood clearance, pretty much cutting a big ass hole in the hood.Builder/Owner of Badass Panther Wagons
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Another Possibility
DuceanaHalf's suggestion got me to thinking, so last night Capridrifter and I put our heads together and came up with a scenario that might work, and keep everything nice and low under the hood.
Rather than using the elbow and a standard throttle body, which would mean I would have to worry about finding an intake that was low enough, could I just use a 4 bbl throttle body like this? Then use 24 lb./hr injectors, ECM from a T5 Mustang or manual trans 351W truck (does such a thing even exist?), and sensors from the 351 truck EFI system. I'm also wondering how/if it would be possible to use a MAF sensor with this system since it is not a standard style throttle body.
Sorry for being so long winded, but I'm just trying to figure out what to do here.
Originally posted by Nathan in MNDuceanaHalf's suggestion got me to thinking, so last night Capridrifter and I put our heads together and came up with a scenario that might work, and keep everything nice and low under the hood.
That is basically the Holley Pro-jection set-up, also that set-up is basically a speed density set-up, not mass airhttp://secondhandracing.com/Home.aspx
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Originally posted by DuceAnAHalfbasically a speed density set-up
And I just looked at the Holley Pro-jection system. That's a TBI setup, which isn't what I'm talking about. I mean just a 4 bbl throttle body, but still with injectors at each port.Last edited by Nathan in MI; 10-21-2006, 02:09 PM.
Originally posted by Nathan in MNAnd this is? Sorry, I'm just not terribly familiar with EFI system terminology, though I've learned an awful lot recently.
Speed density does not use a mass air meter. it uses air temp and manifold vacuum to determine how much air is going in the motor (im sure someone who knows more about it than me will chime in. Im a carb guy)http://secondhandracing.com/Home.aspx
I have seen a 90s 351 F250 with a manual trans and EEC IV computer, so yes they do exist. The truck EFI is batch fire, not sequential efi. You might be better off having a SEFI computer re-programmed, or if you can find the lightning ecm, use that. The lightning ecm is supposedly sequential efi.86 Lincoln Town Car (Galactica).
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Okay, one more question on this situation. If I use a 4 bbl intake and have to have it drilled for injectors, where would I have that done? Is that something a machine shop can do? And what do I ask them to do? Will they know what size to make the holes (assuming I provide them with an injector) and what angle to make the holes at or do I have to figure this out for myself and tell them what I want?
