Instead of taking the valve springs off my brothers GT-40 heads and swaping them onto my E7s im just going to swap the heads onto mine. They are 351W Marine heads and have slightly larger valves. So hopefully ill pick up the 20HP the valve springs were costing, and 30 or so from the GT-40s. Plus ill be able to run it higher than 4500RPM.
Now i just need to order gaskets and my nitrous plate and get the heads swapped over by the 28th.
on a related note we've gotten the AFR 185s bolted down on his. still need to pull the motor and swap out the oil pump.
