Amazing.
    Amazing.
    My Theory about my popin noise was true.. It was bad dist cap rotary button.
    I put a new cap on sat... And was gonna put a new button on to. butt. They gave me the wrong one. So i went and got the right one today ;-).. Set my timing back... No poping not ounce. My timing light dosent work anymore but Eh.
    Also, I have noticed a Increase in Power maybey 15%... Which is makking me to fast, imo..
    Any how heres a heads up to anyone with the same prob. Check your dist cap and button, new parts arnt allways good part's :-D
    Also im getting more and more Amzaed, at how theese car's preforum
    I have just noticed something though. on a little cruse. Theres alot of Unburned gas im loosing. Might this be to bad injectors? I say this due to smell. and Loading up a bit.
      Could be , but there are so many other things that could cause a rich condition....
        ) like the o2 sensor thats old as a fart?
          When the O2 sensors fail or dont give reasonable output, the computer ignores them and tends to run a little rich, so yeah it could be a fried O2 sensor.
            Ok cool, well not cool but it's a dern good place to start. Cant a Engine running lean Blow something btw? ( Tells me if this is next 1st thing to get done or not. )
              If its running lean it can melt the pistons because it will get hot. Ford EFI runs a little on the rich side anyway, and if you have gutted cats it will smell more / different too. If you are getting decent fuel mileage, I wouldn't get super concerned with it, but they are only about $20 so its a cheap fix in any case.
