I ve been driving my car recently for the first time 3 days in a row i went 50 miles around town..... AIt eat two quaters of a tank
MAJOR PROBLEM!!!!!!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Have you checked for fuel leaks?
Originally posted by SLIMso are yous saying it eats a half tank???
tom had a problem like that with his merk
so we fixed it with a 4 barrel edelcrock
dont think that will help anything but ya know!!1983 Grand Marquis 2Dr Sedan "Mercules"
oh you mangs and your carberation........theres something wrong mang.......hard to splain on teh intraweb...........or you full throttle the whole time......need to check all the shit under the hood.......cablemangs 85 vic runs like a raped ape and is stil all stock and gets good mileage...........as pete sais cfi is goodness.......believe me it not that bad when you get all the graemilins out
My suggestion is not to read too much into half tank readings. My car almost always eats through the first 1/2 tank of gas in 80-90 miles, then takes 150-160 to finish the other half. If you think it's sucking gas really fast, go through a ENTIRE tank and make sure. Sounds like you have already checked for leaks. BUT and FYI tip, when you turn your car on (before starting it, just in the on position) the fuel pump gets primed. So turn your key to the off-run-off-run-off-run position several times, then check for leaks. Do this on a cold engine as well, so that if something is leaking on the engine it doesn't evaporate away before you see it.
My car is exactly the opposite of Blaze's. 160 miles to a half tank, maybe 260 and its at 1/8. Calculate your actual fuel economy before getting too worried about it.86 Lincoln Town Car (Galactica).
do a full tune up and replace the T/stat. check for stored trouble codes if possible.
vaccum leaks will also kill fuel mileage.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
Originally posted by 88grandmarqdo a full tune up and replace the T/stat. check for stored trouble codes if possible.
Figure overheating it toasted the new thermostat. Heater output is down so looks like I have to go in there again. If that dosent get my economy back to before over heating will have to pull the air and water temp sensors and check there output with the multi meeter to see if there with in perfered range not just allowed range. I have found that to be important. I have even tested them at the store you wouldnt believe how many are not in the perfered range but are in speck. I have pulled used ones that are better than new ones.Scars are tatoos of the fearless
my comments were directed to the 83countrysquire about his "major problem"2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
