tranny line !HELP!
    tranny line !HELP!
    I had my rad out today so i could take my timing cover off to replace the oil seals, i put it all back together and my top tranny line is leaking right out hte back of the nut, i tightened it up so much that i rounded the nut a little and it still drips out the back, anyone know how i can fix this without replacing the line???
    Is it leaking form the threads or from where the line and fitting connect?
      Is it one of those quick disconects with the plastic pieces in it?
        Replace the quick connect. $5 and your problem will stop.
          well i ended up cutting the line and put a fitting in and joining it together with a pice of high p.s.i hoze so it dosent leak now, to bad i dident check back on hear in time to see that i could have got a new connector well atleast it dosent leak now..
