Toyota parts? What the hell?
    I installed a second electric fan. a small pusher fan from a early 90's Toyota 4-door. This is posistiond mostly behind the bumper since there is a hot spot in the radiator there form the bumper blocking flow at low speeds. It will also double as a fan for the second tranny cooler that is going to go directly infront of it.
    Best of all, both of these pull less than 25 amps combined.
    Whatever works!
      I was just going to say that
        fits good mang
          That fan blows. At least I hope it does, because if it sucked it wouldn't work very well.
            Yeah, i was specifically looking for a front mounted pusher fan. first import i found happened to have it.
              my rdio hs a fen kile tht
              Save a seal, club a liberal.
                Ookay?
                  why the need for 2 tranny coolers? is there something I am missing? I don't have any tranny cooler other than the one built into my radiator.
                    because he has a high stall torque convertor.........the higher stall you go, the hotter the fluid gets........scorching fluid is bad mkay
                      Plus i have an aftermarket radiator with no built in cooler. Tranny fluid can almost never be to cool.
                        oooh I see, I'll probably add one when I get some extra cash.
                          Looks good. Very clean installation, Blaze your work always looks good.
                            Um, thats not Blaze's car
                              Johnny's car is alot cleaner than mine.
