What does setting the TV cable to WOT do? Does it make the shifts shorter and harsher? Also, do I need to use a gauge to check the TV pressure or anything similar or is it as simply as the sticky in this section?
I'm looking into doing this because I've been having some problems with the tranny lately. If I'm crusing at a steady 50-55mph then slow down to 45-40 it slips sometimes. Its also relucant to upshift when coming to a stop from a higher speed. Doesn't like WOT, it will downshift for a few seconds only. You have to floor it a couple of times to get it to stay out of OD to be able to pass someone in it. Its shudders sometimes but I've been in other panthers that done the same thing, usually in the morning.
Tranny fluid and filter are both fine, I had it changed about 5-6,000 miles ago. The fluid is still bright red and at the same full mark it was 5k ago. TV grommet was replaced well before it could break on the stock intake and I have a new one on my HO intake and TB.
