For some strange reason if I turn the key all the way to the right she turns over and over but doesn't want to start. If I turn it just partway it seems to "catch" and start right away. Thanks in adv.
Minor ignition question
Most likely a wore out switch, the part that engages the starter is a rod that pushes on the switch, the ignition is active in the on/run position. Its possible that it doesn't make a connection when you push it too far. Id take it apart and clean the contacts.Chris - A 20th Century Man \m/ ^.^ \m/
Get a new switch. Its a fire hazard on these cars. There was a recall for it at one point but the switch is only like 20 bucks or something.86 Lincoln Town Car (Galactica).
Originally posted by gadget73Get a new switch. Its a fire hazard on these cars. There was a recall for it at one point but the switch is only like 20 bucks or something.
Originally posted by BoxManWere '90 and '91 included in that recall? I've only seen '89 down crispy fried from the switch.86 Lincoln Town Car (Galactica).
You only have to remove the covers. Also, you will have to have a security torx screw to deal with. When you buy the part, check the screws that come with it and go to a hardware store to find the correct bit; or you can break out the stem and use a plain old torx bit that will fit. A very easy procedure all told.
I found it slightly easier to get the lower part of the shroud on and off with the small panel directly below the steering column removed, but no idea how the 90+ column comes apart really. My original screws that held the ignition switch were this completely wierd tamper-proof thing that had just a round head on it. I used one of those sockets designed for removing rounded off bolts to get them out. Tap the socket on, remove with the appropriate sized ratchet. I have a set of torx security bits that I got for $cheap somewhere. I think they were like $5 for the set or something. I used the right one in one of those screwdrivers with the interchangeable bits. The whole process was less than an hour, much of that time spent looking for the aforementioned rounded off bolt socket set.86 Lincoln Town Car (Galactica).
...the logic fails me at that point. If it was ignition switch it should be completely unrelated to engine temperature, and if it was some electrical problem outside of the ignition switch it should not matter exactly how you turn the key to make it start.86 Lincoln Town Car (Galactica).
Had trouble starting her today. Strange thing was I had to turn the key all the way and kind of hard to get the ignition to catch (starter motor was turning no prob.).
Does your car use one or two small terminals on the starter relay? If its using both of them, check the I terminal for +12v while the engine is cranking. If its not working, or the connection between that point and the ignition coil is bad, it won't have any fire while cranking the motor over. Not sure if your car uses that setup or not, just a thought.86 Lincoln Town Car (Galactica).
Poor mans anti theft system
Originally posted by gadget73Does your car use one or two small terminals on the starter relay? If its using both of them, check the I terminal for +12v while the engine is cranking. If its not working, or the connection between that point and the ignition coil is bad, it won't have any fire while cranking the motor over. Not sure if your car uses that setup or not, just a thought.
