CV still overheating
    I'm about fed up with this shit. I've put in a new radiator cap, the radiator from the '88 GM, new upper and lower hoses, new 195 deg. thermastat, and had the coolant flushed . . . and the fucker still goes up to 230 deg. F. while in town. I just picked up a new fan clutch, but I truly doubt that is the problem. I have no fuckin' time or money for this shit. Two goddamn Panthers and both aren't able to go anywhere.
    If it's the water pump, I will not be able to afford the trans for S.U. I might as well buy a fuckin' gun.
    I dunno, the fan clutch could easily cause the issue.
      damn, Where are you getting your water pump from? I got one locally for 18 bux, and its even the aluminum style. I know when I had my car running after the carb swap it ran really hot cause my timing was set way retarded. But I think if your timing was off you would have definetly noticed driving out to SF06 the first time. Also thermostats can be duds brand new. Maybe try running it without a thermostat and see what happens...I dunno I'm trying to give you the least expensive ideas.
        From what I know, the water pump could be original (137K miles on the CV). I'm going to try and get the fan clutch on tonight and test the car.
          Easy way to test the fan is to warm the car up and shut it off and see how long the fan spins once the engine stops. It shouldn't spin more than a few revolutions (2-3)
            You can also watch the clutch face to see if it wobbles. It shouldn't, nor should the fan wobble excessively. The blades might not be perfectly even, and the idiotic spacing will make it wobble some but if it looks like its coupled to the engine through a jello mold, its bad.
            Water pumps are pretty cheap. Its kind of a pain in the ass to change out, but its really not that horrible. If you have the tools, its easily a one day on the weekend taking your time to clean and paint type job. 3 hours if you're just changing it out with no paint or extra time spent.
            Just out of curiosity, what are you using for a temperature sender, a mechanical or an electric? Have you tried swapping out the guage and/or sender from SU just to see if the results are the same?
              Gadget, both cars are using the same type of electrical sending unit. I do have a mechanical gauge that I was going to hook up and test the cars on when I had time. Odd thing about it, even with the 2-core radiator and new thermastat, S.U. still runs 210-ish. The CV runs 195.
              The water pump seems to be holding on for the moment, but I think it will have to go soon. The new fan clutch seems to have done the trick, for now. The needle didn't even move when driving around town and on the highway with the new clutch. The new clutch also came with a bushing to put over the water pump knob. Scott, I did notice on S.U. that the fan clutch and pulley wobble like crazy. Didn't that new pump lack that knob? I will have to get something in there to stabilize it.
              Let's see, which one is the new clutch . . . ?
                That old one was toast. All that shit on there means it was in bad shape...
                  Yeah it blew it's load. When they leak the oil out like that they wont spin enough.
                    hey justin is that new clutch a thermal one sucks about your problems mang my water pump gave out at 131,000 my car used to run 220 befor the new clutch was put in now it runs an ok 210
                      Yes, it's a thermal clutch.
                        hmm didnt notice that........damm..........get a new fan clutch for su too if the age is questionable
                          aluminum radiater and 160 degree thermostat. How hot is your summers? that can be part of the problem?
                            Fuck the 160. You need a 195 on an EFI Ford or you'll toast your plugs and cats, not to mention losing immense gas mileage. The computer will keep dumping fuel until it reaches operating temperature.
                              The 195 tstat in my car runs it between 190-210 depending how hot it is. I've seen it hit 220 on really hot days with the AC on stuck in traffic or something but thats it. As long as it doesn't consistantly run that hot you're probably OK. 200-210 normal running in the summer is about right.
