I picked up the wire but no time between an interview I just had and work to do the harness, plugs, and wires, so I'll just wait until the morning.
Ignition Issues
Ten minutes for plugs and wires? With the stock smog equipment in place? Good luck on that...
New plugs, wires, and ignition coil harness and it's still not even starting. It's sending spark through the wires... guess I need to check the timing now.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
it can be done in ten minutes......but that's rushing
I decided I'm going to pull the motor when I do the HO conversion. I may get my hands on a low mile short block. If I can, I'm gonna build the whole thing and swap over all the brackets and other niceties to the complete engine. It'll make it easier, in my opinion. Easier because this smog stuff must go.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
that's how i did my swap on the towny........secured a 42,000 mile ho shortblock for 150 bucks, bought a pair of thumper heads, got ported intakes on ebay, ho cam from nitrous al, injectors, throttle body, ecm, from the junkyard........got all the pieces together with new gaskets, water pump, balancer, valve covers, and put it all together in a weekend..........next weekend i swapped the engine, and here we are 22,000 miles later
