Hi dose anyone know what this tube is for right in front of the snorko, just wondering beacuse its torn open and im dont know if its important,
breather question
That's not the original air filter assembly. That's off a Mustang or Capri, or possibly a custom made replica.
Mine looks like:
Where does the hose go?1990 Country Squire - under restoration
That may be the PVC tube.89 CV LX 225/60 x 16 tires, CC819 rear springs, Front & rear sway bar, trans & PS cooler from 90 cop car. KYB shocks, F-150 on rear. Dual Exhaust w/ H pipe. Dark brown door panels, carpet, steering wheel, trim parts from a 87 Mer GM. Power front buckets from 96 Jeep Cherokee. LED'S front & rear. 3G Alt from a 97 Taurus wagon 3.0. Electric fan. Rear axle from a 97 PI 3.27 with disk brakes. Headlight relays.
thats for your old school fuel evap canister - that hose should go down under the battery to a plastice box.
older ones didnt use a valve, they just sucked on it through the air cleaner through that hose. my 77 was like that. No computer controlled evap jibba jabba.
Worst harm it will do is make a smell.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
