I was driving it today it locks up like no other when you slam on the them... since i am trying to make this go fast and cool and SAFE so any way i can
Is there any way to install ABS on my 83 wagon
first of all are your brakes good? I'm sure you could install abs but it would be one hell of a project first you would need the abs pump also add some new lines mabey get a abs computer from a mark 7 or towncar install wiring speed sensors install lights for the guadge it is possible but would time cumsuming and cost money
ABS... I wouldn't try it simply because it shouldn't be needed.
Don't slam on the brakes and you'll be fine, if not better off. The techique is called threshold braking.1990 Country Squire - under restoration
Threshold braking is a tough thing to do with stock brakes. ABS would be very tough to do and would require changing a lot of stuff on the frotn and rear suspension. Do the 98-02 brakes and it will become a moot point.
Also, just doing a big drum upgrade (if it doesn't already have them beign a wagon) or rear discs should help a good bit. Tires, shocks, and springs all also contribute to the problem.Builder/Owner of Badass Panther Wagons
rear wheel cylinders are probably trash or the axle seals are leaking and getting gear oil on the brake shoes........shitty tires will cause the brakes to lock up easilly too
best bet isd the 98-02 brake upgrade.......my wheels will not lock unless you slam real hard on the brake pedal
well they are all new brakes and winter tires i have shocks and a new springs soon but abs will not be going in i dont have the time maybe in futuresigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Also, just doing a big drum upgrade (if it doesn't already have them beign a wagon) or rear discs should help a good bit. Tires, shocks, and springs all also contribute to the problem.Chris - A 20th Century Man \m/ ^.^ \m/
