had and idea of an intercooled intake... it basically would be set up like a normal turbo charged vehicle with a front mounted intercooler. for clearance issues on an older box body u could use a front bumper with the cutouts in the middle and mount it behind the bumper... plumbing would be aluminum of course. think any benifit would be achived with a non turbo intercooled intake LMAO. could always slap a intercooler juice sprayer on da front for a colder shot.... AGAIN just a bumfuck idea! might be something to try, if no ones done it before....
Intercooled intake idea?
I doubt you would see any thing from it, A CAI would be 1000x better. They use intercooler to cool the air coming off of a turbo or supercharger cause if not the air temp would be really hot 150-200+* because of the exhaust heat on a turbo and friction. Plus the intercooler probably wont cool incoming air too much more if its the same temp as the air flowing over the intercooler. Not to mention the restriction from the intercooler alone.
Originally posted by MercmarquisI doubt you would see any thing from it, A CAI would be 1000x better. They use intercooler to cool the air coming off of a turbo or supercharger cause if not the air temp would be really hot 150-200+* because of the exhaust heat on a turbo and friction. Plus the intercooler probably wont cool incoming air too much more if its the same temp as the air flowing over the intercooler. Not to mention the restriction from the intercooler alone.http://secondhandracing.com/Home.aspx
What he said, and the corrolary is heat is lost when its decompressed, hence propane bottles frosting up with heavy use. Its actually this exact principal that makes air conditioning work. Its high pressure on one side, and low pressure on the other. It expands from a liquid form to a gaseous state via an oriface tube or expansion valve, is blown at high speed through the evaporator and is moved to the condensor to be re-chilled back to a liquid state. Heat is transferred from the cabin air to the evaporator to, well, evaporate the refrigerant and the exact opposite happens at the condensor. Heat from the consensor is exchanged with ambient outside air to bring it back to a liquid.Last edited by gadget73; 09-04-2006, 11:11 PM.86 Lincoln Town Car (Galactica).
Originally posted by gadget73What he said, and the corrolary is heat is lost when its decompressed, hence propane bottles frosting up with heavy use. Its actually this exact principal that makes air conditioning work. Its high pressure on one side, and low pressure on the other. It expands from a liquid form to a gaseous state via an oriface tube or expansion valve, is blown at high speed through the evaporator and is moved to the condensor to be re-chilled back to a liquid state. Heat is transferred from the cabin air to the evaporator to, well, evaporate the refrigerant and the exact opposite happens at the condensor. Heat from the consensor is exchanged with ambient outside air to bring it back to a liquid.
PV = nRT
Turbos push air through the intercooler, then to the intake. If you tried to use it an intercooler on a non turbo or supercharged engine, all it's going to do is cause a restriction in the flow of air.
It's fun to hear CV/GM'ers talk about turbos...I do it all day long at work.
~Adam
'85 2-Door Crown Victoria
302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
'04 Crown Victoria LX Sport, '02 Jeep Liberty
'83 Suzuki GS 1100E Motorcycle[/color]
I like the idea of cooling an air intake with the A/C bottle thingy. All that coldness gets wasted under the hood, why not use it to cool something.
You could let it idle with the AC on to get nice and cold, then do your run with it off.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Originally posted by 85crownHPP*I like the idea of cooling an air intake with the A/C bottle thingy. All that coldness gets wasted under the hood, why not use it to cool something.
You could let it idle with the AC on to get nice and cold, then do your run with it off.Builder/Owner of Badass Panther Wagons
Hmm two turbo coupe turbo's and one 302....intercooler anyone?
anyway for non turbo I would use dynamat around the CAI pipe and wrap over that with one of those intake covers they have in summit catalog I'm sure that would keep heat awayLast edited by interceptor1985; 09-09-2006, 06:11 AM.
Originally posted by jasonhFord was gonna do that on the new Lightning, was supposed to gain 50hp. I guess that idea is scraped along with the rest of SVT...Scars are tatoos of the fearless
