The P heads are easy to work on with the FRPP headers. I check my pugs in between rounds when I run nitrous and I have no problems. The plug angle is no reason not to use them. P heads with the stock Explorer manifolds are easier to work on than your stock CV.
My stock CV? Maybe you should look at the sig. I can get to every spark plug with a solid 6" extension, even the oe behind the AC compressor. And GT40 intake is better.
So a 96 Explorer 5.0 i will need different headers for I thought that was 97 that spark plugs were relocated
and which is the better upper intake a cobra or gt40
I have seen a build up of the mustang HO 5.0 FI STOCK that pushed the mustang into 10's with a new trans in muscle mustangs and fast fords magazine
Define STOCK and which issue you saw this in. There is NO way that a stock spec cam and E7 or even GT40 heads are going to get you into the 10's NA. The best Factory Stock FI 5.0's with GT40 heads are only in the high 11's. These engines are making over 350HP and there are big bucks into the "stock" rebuilds.
The older mustangs (ones not using the BOSS) didn't seem to use the Windsor 302, but instead used the 289. Those went into 300hp+ arena.
The 271HP K code 289 was over rated even by gross HP standards. The LOW rise intake sucked. The 306HP Shelby 289 had a very high rise dual plane intake and the HiPo solid lifter cam with a Holley to make its rated gross power.
thats wat i thought so is a cobra intake better or a gt40 intake
now wat type of came should i get and rockers and springs should i get also looking to make 300hp or more and 300ftlbs of torque
Get a complete Explorer motor and use the Explorer GT40 style intake. TFS Stage 1 cam and the valve and spring kit from Central Coast Mustang.
I will personaly never use the heads because of the spark plug relocation. One thing I do consider (And Ford should realy start doing this as well) is how difficult it is to work on.
I agree with the aluminum vs cast iron, but even in your statement, the P heads are better unmodified than 40s. I will personaly never use the heads because of the spark plug relocation. One thing I do consider (And Ford should realy start doing this as well) is how difficult it is to work on.
This has been discused in great detail many times. maybe with money spend on porting and other stuff GT40s are better than the P heads, but stock to stock GT40P heads are better and have better flow numbers.
I have a couple machine shops I do business with. Both actually worked with Ford at one time. One even has desplay engines in there show room many of wich I did much of the design work for. The other did tons of dyno work for ford and Ford was there backer on some forms of truck racing. The other builder doess NASCAR engines. One class could only use stock heads. They always ask if I have some 40 heads they dont want P heads. P heads are easier to find though.
P heads get some better flow numbers but dont flow air across the combustion chamber as well because of the big lump of a spark plug boss in the way. They also dont have the best flame front. Ported P heads flow the same as 40s but the 40s will kick the P heads ass because the 40s will accept larger valves the P heads wont. So if you want to up grade the heads later you got to get some 40s or E7s. Best bang for the buck is some cheep E7s have them ported with stock valves some better retainers or stock ones better springs for around 500 bucks you get better performance.
I have had all thesse heads on my flow bench stock and ported all of them. Flow numbes can look good on a bech to and not preform well on an engine because air speed is not given as a factor. Air speed realy boosts power. Bottom line my shop wold never recomend P heads. We also do not recomend aluminum heads for most 302 builds.
If you ever want to replace your engine with a real ford replacement they have very powerful crate engines and one of them is the GT40 302 and a similar one the 347 (not the one we are getting). I have seen a build up of the mustang HO 5.0 FI STOCK that pushed the mustang into 10's with a new trans in muscle mustangs and fast fords magazine
None of those are within the budget. He can get a explorer motor, cam, valve springs, and headers for about 1 grand total.
P heads are over rated. The 40s are a better choice.
Go with GT40 upper and lower intakes, and GT40 heads. If you're gonna rebuild the engine, get a larger camshaft. And if you haven't, redo the exhaust. After that you should get some great results.
Leave a comment:
