Originally posted by Blaze86Vic
what is the most power stock 302 every built
Originally posted by MercracerOnce you add the turbo, it is no longer stock. I personally have seen those kind of times with a power adder so I am not refuting the potential with a power adder. Using that definition, I have seen a "stock" 98 Cobra motor run 9's. Nothing was touched internally to the motor.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
just getting some facts straight
I want a 96 Ford Explorer motor b/c they have GT40 heads and my headers i have now will fit
But do I want the stock upper intake (gt40) or should i get a cobra or is there no difference i didnt think i found the anwsere up there so if i m being redundentsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
83countrysquire, keep in mind that to use those intakes, you'll need to upgrade from CFI to SEFI, mostly a wiring hassle.1990 Country Squire - under restoration
Just semi-OT, comparing old engine power ratings to new is kind of a crap shoot. The power ratings were done differently back then, gross numbers with no accessories and whatnot. Take that same motor with the huge power ratings and compare it to a new on the same dyno, and you'll get some rather different results. Factory power figures also aren't the most reliable so using them to judge stock horsepower is not neccesarily useful.86 Lincoln Town Car (Galactica).
moet of my stuff isnt opinions more fact. What has worked or what is. On a flow bench bigger flow numbers dont always mean more power. The head with higher air speed a better combustion chamber faster burn is going to win. Best bang for the buck ported E7s with stock valves flow 220 at .5 lift actually that dosent show it alll becsause they will flow more at every lift point. At that point go with a GT40 tubular intake or a P intake.. I f you can get the intake to flow 220 which it might need ported too. But will say the intake flows 200 yo ugot 400 HP. What are P heads or 40s going to cost?
All stock E7s maybe 100 or less I do the port work for 500. Bigger valves, better springs, retainers, studs, maching for studs is extra. A carb set up will get you 50 hp more than SEFI for less.Scars are tatoos of the fearless
Originally posted by turbo2256b. What are P heads or 40s going to cost?
All stock E7s maybe 100 or less I do the port work for 500. Bigger valves, better springs, retainers, studs, maching for studs is extra. .
There are good complete Explorer motors for $500 or less. If you sell the intake for $200-250, you have $300 or less invested in a long block. If you just need the heads, it is easy to sell a good shortblock for $150. The throttle body can be sold for an additional $50. I have made money by just selling the intake and shortblock. I had a free set of heads and extra money in my pocket to put towards the heads when I was done. That leaves you an investment in a set of heads that can give you 325+HP on a 302 or 400HP on a 351 without porting for $150 or even less. Springs and hardware are cheap and you already have larger valves.
If you just want to buy a set of used heads, they can be found for $200-300 a pair depending on condition or a little more if someone freshened them up already. The most I ever had totally invested in a set of P heads was $600 including shipping and that was brand new castings with stainless undercut high flow valves and new high lift springs with new hardware.
$600 included a fresh cut on the seats and valves and assembly.
yeah i know about the wiring but someone told me i can just use a box MFI wiring harness from like 89 or 90 or 91sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Originally posted by turbo2256bI would say the old Shelby Mustangs. The Boss 302 was under rated pull there rev control box and they would fly.
And I don't know why the Boss 302 wouldn't count in the "which 302 has the most power" debate if we're talking about Ford factory power.
And the Boss 302 wasn't Shelby. In fact, one of the many reasons that Shelby got pissed and left Ford was because there were SERIOUS rumors that the Boss 302 program was funded by money funneled from his program behind his back.Last edited by mercenvy; 09-01-2006, 10:28 AM.My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
Originally posted by mercenvyAll pre-67 Shelbys had the 289, and the '69 GT 350s had the 290 horse 351W.
Originally posted by 83countrysquireyeah i know about the wiring but someone told me i can just use a box MFI wiring harness from like 89 or 90 or 9186 Lincoln Town Car (Galactica).
