Hey guys, i pulled my codes, was woundering if you guys could help me decipher. )
Here they are
this is koeo
22= Manifold absolute preasure (MAP) Sensor Or Barometric preasore ( Bp) Sensor- Signal voltage out of specifacation ( Engine off ) or not at normale level's ( Engine running )
34= EGR valve postion ( EVP ) sensor or feedback EGR ( PFE ) Sensor : signal voltage out of self test specfication or limit's Or, signal voltage above closed limit during normale engine run oporations or, signal indacates insufshiant flow EGR flow
67=Inproper signals are being sent from either (NDS) (NGS) (NPS) (CS) (MLP) OR (ACC) OR A/C ON DURING SELF TEST
85 = Canp solenoid - circutefailure or transaxel prob 3/4 shift solenoid circute failure failure. or, (eca) status-adaptive "Lean" limit reachedin fuel controle program.
1
then same as above
Ok, my timing, well it said to hook up a timing light, i did that and turn the car over, ( I made sure it was set at 10 base ) it then say's that it will make some codes come up and to disreguard them. they never came up anyways though, and the last thing it said is when you reconnect your connection ( Spout connector ) it should have a increase of rpm's if it did you pass, so i passed. )
And last was the koer
All it did was one long beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeep it nver stoped, even after 5 min's :-/ eh, and it dosent say anything about this in the book.
Thanks's guy's you all know evreything i know now )
D.K.
Here they are
this is koeo
1
then same as above
D.K.
