engine (re)build is starting... (big duw)
    so, we're starting on the engine rebuild on the 84. here's some pics:
    We've got the oilpump in and are flushing the block oil system. The carb is a quadrajet 4bbl
    GMNRadio DJ, Podcast Co-Host
    1984 Ford LTD Crown Victoria - Drag Car.
    99 Ranger 2.5 - Parts hauler and Pit truck.
    03 Mustang 3.8 Convertable - Head Gaskets fukered up
    95 S10 93 Accord
    Your camera focuses better on the dust on the lens then the giant engine block its pointed at :lol:
    Why the quadrajet, just something you had around?
    '80 Town Coupé
      dad got it for 20 bucks.
      initially we're going to disable the secondaries, as the primaries will most likely be enough
      oh, yea, my camera doesnt like taking darkish pictures
      95 S10 93 Accord
        From what I've heard, quadrajets always tend to have flat spots that will drive you nuts at the track. I don't know what would happen if you disabled the secondaries though, as they might be what cause it. Again, this is just what I've heard from a couple people.
        Nick
        88 Colony Park LS
          A lot of people like the Q-Jets, they are very tunable if you know how to work on them.
          I have two smog-era ones on some GM products (A '76 Cutlass and a '73 GMC Sprint). Both have 350's. The Cutlass runs like a raped ape, the Sprint runs like doped Granny.
          So what kind of build is this going to be?
            Wow...focus. I know you want to show off your project, but take an extra minute to get some clear pictures.
            '85 2-Door Crown Victoria
            302 HO, -0.022" E7 Heads, Weiand Dual Plane Intake, Edelbrock 1406 Carb, Mechanical Fuel Pump, HEI Distributor, 180* T-stat, Transgo Shift Kit, HO Governor, Lokar TV/Throttle Cable Setup, B&M Torq Master 2000 RPM Stall Converter, FRPP Trans Cooler, Mustang Shorty Headers, 2.25" Dual Exhaust, Flowtech H-pipe (no converters), Hooker AeroChamber Mufflers, Side-exit Exhaust w/ Chromed 2.5" Tips, '02 PI F/R Shocks, Cut 2004 PI Front Springs in the Rear, PI Rear Sway Bar, 17" SAP Wheels, 245/50/Z17 Michelin Pilot A/S Tires, Cold A/C, Cruise Control, 4.10 Rear End Gears, Trac Lok Diff.
            '04 Crown Victoria LX Sport, '02 Jeep Liberty
            '83 Suzuki GS 1100E Motorcycle[/color]
              A quadrabog on a ford, hmmm, I dunno. I like em on my GMs.
                sweeet build that sucker!!!
                but doesnt the crankshaft have to go in before the oil pump????
                  I guess you didnt catch the part where I said my camera doesnt like taking low light pics. It's very spotty sometimes.
                  Right now, we're just going to get her running with a mostly stock rebuild. There will be a little bit of werk done to it, but mostly bearings and such only. We need to rebuild a 50+ year old 10kw willey's jeep generator and the only place we have to do it is where the box is sitting.
                  95 S10 93 Accord
                    Q-Jets in proper working order are OK, but when they get screwed up, forget it.
                    And I think you're missing a crankshaft, unless you're going for that vibration-free uberstroker.
                      did u take a thermactor pump with you?
                        dont need a crank shaft to run the oil pump through the passages to make sure all the oil paths are clean
                        scott, I forgot to get the pump. I'll be coming back up in october some time to pick up the c6, i'll get it then.
                        95 S10 93 Accord
                          Looks like fun,wish I could help!Are you just rebuilding it as the standard Vic 302,or are you upgrading to the HO parts along the way?
                            Oh OK,just saw that you said your going with a mostly stock rebuild.Not even gonna throw some E7's on there?
                              no e7's. I have a set of D0OE heads that are slightly modified that will go on the race motor which we will start building after the generator is running.
                              95 S10 93 Accord
